Re: 42s: programming a line of -2 Message #2 Posted by Vieira, Luiz C. (Brazil) on 4 Sept 2005, 2:21 a.m., in response to message #1 by rob
Hi, Rob;
to enter this program line, simply press [2] [+/-] The [+/-] key will change the sign of the number being currently entered, either in normal or in program mode. After the [2] [+/-] just press [shift] [COMPLEX] and go straight ahead with the next steps.
You can follow the same reasoning in step #249: [1] [+/-]
I hope you succeed.
Luiz (Brazil)
Edited: 4 Sept 2005, 2:23 a.m.
