Re: HP 49G Memory recover Message #2 Posted by I, Claudius on 20 Aug 2005, 5:49 a.m., in response to message #1 by NA
RPN Mode -
The command [:2:Home ARCHIVE] will store all your directories with programs, note files, plots, custom keys, etc, securely in in the Flash ROM of Port 2.
The command [:2:Home RESTORE] will restore the saved Home setting of the archive.
If you have favorite flag settings, save them as a list. For example, {-117 SF -116 SF} 'Flags' STO. Then after the restore operation, put the Flags file on the stack, then EVAL. The same can be done for the ->KEYTIME command, if you have a favorite setting of that.
