Re: Your Opinion of 17BII+ Calculator? Message #3 Posted by Vieira, Luiz C. (Brazil) on 18 Aug 2005, 4:29 a.m., in response to message #1 by Jeff
Hi, Jeff;
I own many HP calculators, and I have some financial models (37E, 38E/C, 12C, Platinum, 14B, 17BII, 19BII, 10BII and recently an HP17BII+). I mainly use scientific models, but when needed, I prefer using either the HP12C or the HP17BII.
I must confess I did not use all features available in the high-end models (HP17BII, HP19BII and HP17BII+), but I tested each example in their manuals. Some features I take as necessary, others are not used that much, but if you need currency conversions, be aware of time and date, set appointments, use a custom set of expression to solve for any arbitrary variable or work with more than one single cash flow data set, then the HP12C cannot follow you. You`ll need something like the HP17BII+.
I must tell you I prefer the HP17BII or the HP19BII for the HP17BII+. Keyboard feel/reliability and layout are determining in this choice of mine.
And to tell you the very truth: if it is algebraic/RPN selectable instead of algebraic-only, I'd go for the HP14B. I like using it, but sometimes I key in one number, press [INPUT], key in the second and press some two-number function keys ([+], [÷], etc) waiting to see the answer... My bad, I know, my bad...
I bought the HP17BII+ in order to know about it and to be able to use it as it is. I just complaint about the right-most, top row key: it fails from time to time. All of the rest is fine so far.
Best regards.
Luiz (Brazil)
