Re: HP17BII - stat problems and/or 42SX Message #2 Posted by Vieira, Luiz C. (Brazil) on 11 Aug 2005, 2:00 a.m., in response to message #1 by Jose Sanchez
Hola, Sanchez; como estás?
I loaded the data you provide and I obtained 9.12688336728 as for standard deviation (HP42S, [shift][SHOW]). I wonder what 8.85 stands for; should that be another statistical tool you actually used? Anyway, when you mention HP42SX do you mean HP42S or HP48SX? Each case is a different input sequence.
About the HP17BII, I also obtained the same value above. In the HP17BII you should follow this: [shift]MAIN
[SUM] (optional: [shift][CLEAR DATA][YES] to start a new set)
key in each number and press
[INPUT] (the display shows index for next input and current total)
After last number, press[INPUT] and press
[EXIT] to exit input sequence. To compute standard deviation press[CALC] You'll see many opetions. Press[STDEV] and you'll seeSTDEV=9.13 Press[shift][SHOW] for full precision.
Please, let us know what is the other calculator you have (HP42S or HP48SX). Hope this helps for now. If not, please post again.
Best regards.
Luiz (Brazil)
Edited: 11 Aug 2005, 2:04 a.m.
