Re: HP 37C calculator batteries Message #6 Posted by Katie Wasserman on 10 Aug 2005, 10:00 a.m., in response to message #5 by Peter Geiser
Yes, all the Spice series calculators (31E, 32E, 33E, 33C, 34C, 37E, 38E, 38C) use the same battery pack. In fact all the calculators in any HP calculator series use the same battery pack, the battery pack is a good way to define "series".
(Although some would argue that the 10, 19C, 67 and 9x are properly in the Woodstock series. Then there's the 75C/D which uses the same battery as the classic series, so that's sort of a problem too.)
Edited: 10 Aug 2005, 11:20 p.m. after one or more responses were posted
