Re: Repairing card reader motor on HP-65? (just a possible cause) Message #4 Posted by Tony Duell on 3 Aug 2005, 3:46 p.m., in response to message #2 by Vieira, Luiz C. (Brasil)
The motor control circuit is built into the sense amplifier chip (Only HP would try and put a low-level read amplifier and a DC motor controller on the same chip, only HP could get it to work :-)). It's possible that it's failed. The sense amplifier chip is the one on the card reader PCB, of course.
As others have suggested, disconnect the motor from that PCB (on most 65s the wires are soldered in place) and run it from a 1.5V -- 3V PSU. If it doesn't run, take the motor out (2 tiny screws alongside the worm gear) and try it again. If it runs properly now, look for mechanical problems.
If the bare motor doesn't work, try putting 1 drop of watch oil (not WD40!!!) on the bearings. That may get it going again.
I have never tried to open up one of these motors, but it might be possible.
