Re: 48g Message #3 Posted by Howard Owen on 28 July 2005, 3:50 p.m., in response to message #1 by brian goodger
As mentioned, the calculator has a hierachical file system. To get to the "root" of the file system, press 'right-shift home'. From there you can proceed with your search as mentioned above.
If you recall the names of the programs, you can type the name and press EVAL to execute the program no matter where you are in the hierarchy. (Press alpha-alpha to set alpha lock, then type the name with the alpha keys. Press alpha again to exit alpha lock, then press EVAL.)
Finally, if you care about those programs, and if they are non-trivial in size, you should back them up to a PC using a serial cable and software. (You can get the latter at hpcalc.org.)
