Re: Look HP41CX + QUAD MEMORY Module ? Message #2 Posted by Vieira, Luiz C. (Brazil) on 29 June 2005, 4:59 p.m., in response to message #1 by gileno
Hi, Gileno;
AFAIK, the HP41CX has all 'main memory' available, as it happens with the HP41CV. If you use a quad module, operation may disrrupt, i.e., in some circumstances the calculator may not work properly. All comands that access memory will cause both quad memory contents and main memory contents to answer, and if any of them delays a bit, bus may stuck. Anyway, it may work perfectly fine, though...
Cheers.
Luiz.
