Re: HP41 Module Housings/Connectors Message #2 Posted by Christoph Klug on 17 June 2005, 4:30 a.m., in response to message #1 by Phil Green
Dear Phil,
best solution would be creating Double X-Memory modules : Take two X-Memory modules, open them and place both internal pcb´s in one housing. Then you have the second module shell available for your own custom module application....
Some details about the internal wiring of Double X-Memory modules you find in the HP-Museum article folder :-)
Best regards - Christoph Klug
