Re: 9114B battery Message #4 Posted by Tony Duell on 14 June 2005, 6:54 a.m., in response to message #1 by Jack
If you have the battery housing (which includes the charger PCB), you can replace the battery itself with 3 2.5Ah Cyclon cells (these are cylindrical lead-acid cells) wired in series. As usual, the red wire is positive.
If you are missing the entire battery housing, you can power the 9114 using a 6V supply (it doesn't need to be too well regulated) connected to the 2 pin mini-jones connector inside the cavity on the back of the 9114. I can't remember the polarity, but if you take the 9114 apart (Torx screws on the bottom), you can see the back of this jones plug, again the red wire is +ve.
Be warned that a 9114 can draw well over 1A from the battery, so you need a reasonable PSU.
