HP-45 versions Message #2 Posted by Bernhard on 13 June 2005, 1:12 p.m., in response to message #1 by Bennyboy6
AFAIK, very early HP-45 had a small stainless steel strip near the power switch. Later ones only had silver galvanized plastic there that wears off and then looks ugly. Inner values also do differ: my oldest one (mid 1973) has completely golden galvanized keyboard contact strips, LED module pins and PCB traces. It also has a 8-pin clock driver and the reset circuit is discrete transistors. My later ones have less gold (neither in keyboard, LED nor on the PCB) and a combined 16-pin clock driver/reset chip. As for the stopwatch, all those in my possession have the same HP part numbers on their microcode ROMs (1818-0057 and 1818-0082, including one made in spring 1975, so I guess the hidden stopwatch should be there in all HP45s built between the 33th week of 1973 and the 20th week of 1975 (date code of oldest chip in the machine).
