Re: How to handle the broken battery door of 19BII Message #6 Posted by John L. Shelton on 10 June 2005, 5:16 p.m., in response to message #1 by Nuttv
If you want a quick-dirty-functional solution, I've found hot-melt glue solves a LOT of problems. It holds things together well, but is removable later, usually without damage to plastic, metal, glass, and other smooth surfaces.
So, you could use HMG to hold some batteries in place, and later remove the glue, by peeling, when you need to change the batteries.
Obviously, this isn't a good solution for the serious collector wishing to keep a calc in pristine condition.
