Re: Nonpareil display improvements Message #2 Posted by Mike (Stgt) on 2 June 2005, 6:39 a.m., in response to message #1 by Eric Smith
Hi Eric!
Compiling nonpareil-0.68 under CYGWIN_NT-5.0 i686 1.5.17(0.129/4/2) 2005-05-25 19:38 reveals following:
$ scons
scons: Reading SConscript files ...
KeyError: 'DISPLAY':
File "SConstruct", line 220:
duplicate=0)
File "/usr/lib/scons/SCons/Script/SConscript.py", line 581:
return apply(method, args, kw)
File "/usr/lib/scons/SCons/Script/SConscript.py", line 508:
return apply(_SConscript, [self.fs,] + files, {'exports' : exports})
File "/usr/lib/scons/SCons/Script/SConscript.py", line 239:
exec _file_ in stack[-1].globals
File "src/SConscript", line 172:
str2png_env ['ENV']['DISPLAY'] = os.environ ['DISPLAY']
File "/tmp/python.572/usr/lib/python2.4/UserDict.py", line 17:
def __getitem__(self, key): return self.data[key]
Nonpareil-0.67 compiled and installed perfectly, but:
$ nonpareil hp21
error opening object file
fatal error: can't read object file '/usr/local/lib/nonpareil/hp21.obj'
BTW: HP-12C works nice on VM/ESA
Ciao.....Mike
