Re: HP49G calculator memory problems(please read, I need help on this ASAP!) Message #2 Posted by Arnaud Amiel on 21 May 2005, 2:24 p.m., in response to message #1 by deleted
Use the [<-] (delete) key.
If you keep pressing it while your 49 is turning on you should be able to delete the library. I guess however that you will have lost all your memory.
Good luck
Arnaud
