Re: Diagnostic ROM for 71B Message #9 Posted by Eric Smith on 3 June 2005, 10:20 p.m., in response to message #7 by J-F Garnier
The Diagnostic ROM may be a true take-over ROM, as the port 1 includes the OD signal to disable the internal ROMs.
The HP-71B Service Manual states that the diagnostic ROM must be used in port 1.
Using a logic analyzer to the Saturn bus will not be so easy, because you will have to disassemble the bus commands to decode address and so on,
Not a problem. I've written program to decode logic analyzer traces from other HP calculators, as well as from many other things. I also recently needed to be able to use a waveform viewer for logic analyzer dumps. There's a standard digital waveform file format, VCD ("Value Change Dump"), so I wrote la2vcd to convert the files from my HP 16500B.
and you may not sure that all addresses are fetched.
If it's like other HP diagnostic ROMs, it will have the
ability to check itself, by computing a checksum.
An other way would be to use a small assembly language routine running in RAM to copy the content into a 32k independant RAM.
That's been suggested. But if I'm not mistaken, as soon as you try to plug in the diagnostic module, you'll get a non-maskable "module pulled" interrupt, and the vector is in the ROM.
