Re: Recall Argument capability Message #2 Posted by James M. Prange (Michigan) on 15 May 2005, 7:16 p.m., in response to message #1 by Gordon
On the 28 series, the command is LAST, and on the 48 and 49
series, the command is LASTARG, although LAST still compiles to
LASTARG. On the 49 series, LASTARG can be invoked by LeftShift ANS
(over the ENTER key).
UNDO is different; it retrieves the last stack (assuming that last
stack saves are enabled). Also, UNDO isn't a UserRPL command; that
is, although the operation can be invoked from the keyboard, UNDO
is not a programmable command.
Note that the last command line, last arguments, and last stack
saves can be toggled from menu 69. You can get to this menu by
holding down LeftShift and pressing CUSTOM (over the H key), and
then pressing the MISC menu key.
Regards, James
