Is my 41 sick ? Message #1 Posted by denis on 14 May 2005, 7:24 a.m.
Hi all,
My 41 cv have a problem. When I switch in user mode and type any of the key of the first two rows the calc freeze!!
The only way to go on is to remove/replace the batteries.
I process with no modules inside and do a backspace + on to clear the memory, but the problem still remain. It appear suddently, no specials manipulations before...
Read this manip: If I assign a program to a key, when I switch in user mode the program is called. So the problem is only when there is no key assigned...
After that, if I de/assign the key ( by asn an empty string) then the problem appear again!
Is it the begin of the end for my 41cv ?
Is there a better way to be sure that the memory id really cleared ?
I love my 41, so please help me....
-Denis.
