Re: HP 15C metal trim refinish ?? Message #2 Posted by Vieira, Luiz C. (Brazil) on 11 May 2005, 12:57 p.m., in response to message #1 by Rick Opp
Hi, Rick;
the metal trim you refer to is the aluminun frame in the display? If so, removing it is possible, but it should be used some material to melt the glue used to hold it in place. Other contributors in here succeed using some harmless chemicals, but I actually do not remember the main component used.
In time: if anyone reading this post knows, please, what is the best plastic gule that's used to melt plastic in calculators cases? I know that there is an active component that melts the plastic so it fuses the parts with each other, but I don't remember which, too...
Thanks and success, Rick. Please, consider that if the HP15C you bought is working fine, you have a workhorse in your hands. The scratches are easier to deal with than a deffective unit. Please, consider that this words come from someone that has a daily-used HP15C that has scratches since the day it was bought.
Best regards.
Luiz (Brazil)
