Re: Problems with EMU42 for hp28S Message #4 Posted by Christoph Giesselink on 27 Apr 2005, 2:15 p.m., in response to message #1 by Arnaud Amiel
In the case of a bad KML script the OK button of the "KML Script Compilation Result" dialog is disabled. I think that you have a wrong ROM image. You should get
[e:\hp42]LEWISCRC.EXE HP28S.ROM
SACAJAWEA/LEWIS ROM Test V1.00
Unpacking data...
1st Lewis CRC Pass 0 = FFFF
1st Lewis CRC Pass 1 = FFFF
2nd Lewis CRC Pass 0 = FFFF
2nd Lewis CRC Pass 1 = FFFF
CRC ok!
[e:\hp42]
when you are doing the CRC test. I get your result of a blank display in the case when I'm using a HP28C ROM image with Emu42.
The MD5 checksum of the HP28S rev 2BB ROM image is
353948e6c236fb570d1370dbff7c83fc *HP28S.ROM
Christoph
Edited: 28 Apr 2005, 2:45 a.m. after one or more responses were posted
