Re: INPRT is the capturing prgm (was: Can a HP 42S print to a HP 48G or a to PC?) Message #4 Posted by Vieira, Luiz C. (Brazil) on 23 Apr 2005, 9:45 p.m., in response to message #3 by Marcus von Cube
Hi, Marcus;
there is an article writen by Jordi about the translation of some codes (remapping) that occurs when the HP42S is sending data to the printer. I don't thave the link, all I know is that it is available at HPCC.
I had some 'issues' when creating the HP42S TTF mainly because of this fact, too. I also had to replace some characters for others after transfering data from the HP42S to the HP48. As an example of what I faced when creating the TTF file, both up-arrow and down-arrow characters in the HP42S LCD are sent as '^' and 'v' to the printer (82240A or B), and you see R^ for roll-up and Rv for roll-down in the hardcopy. I am not quite sure about the reasons, but I guess it is because of the two versions of the HP82240.
Maybe you already know about this, but it is harmless to mention, right? ;-) The HP82240B accepts codes to be 'interpreted' amongst two sets of characters, ROMAN8 and ECMA94. The 'ASCII' range (3210 to 12710) of them both is the same, but characters from 12810 to 25510 match in only a few cases. Codes 14410 and 14510 are, respectively, up- and down-arrow in ECMA94, but they are 'µ' (micron) and 'LF' (line-feed symbol) in ROMAN8, respectivey. So, it was wise to use '^' and 'v' instead, that works the same for both printers. There are also other characters that were remapped, but I don't recall them by heart.
About alignment: I keep the HP42S about 1/3 of an inch higher than the HP48 when transmitting. I experienced some problems wehn both were leveled.
Hope this helps a bit.
Cheers.
Luiz (Brazil)
