HP Forum Archive 15
Short & Sweet Math Challenges #8: Squares !
Message #1 Posted by Valentin Albillo on 20 Apr 2005, 10:09 a.m.
Hi all, long time no see:
After many months have elapsed since I posted the last S&SMC, here's a new one which certainly lives up to its title. Should you feel like it, grab your favorite HP calculator(s) (any programmable one will do), then try and solve this
Challenge:
  1. Find a 10-digit square which consists of just two different numbers, from 1 to 9 (0's not allowed). For example, this would be a solution (featuring just the digits 1 and 3):
                    3113311313
    if said number were a square which, alas, it isn't.
    The solution is unique. You're expected to produce a program for your chosen calculator(s) that upon running will find a solution, also making sure there are no others. If you succeed, you may want to extend your program to also:
  2. Find all 10-digit squares which consist of at most three different numbers, from 1 to 9 (0's not allowed). For example, this would be a solution, (featuring just the digits 3,5, and 7):
                    5733753373
    if it were a square, which of course it isn't. There are 48 solutions in all.
As stated, you must produce a program for your HP calculator(s) that will compute and output the solution(s), the shorter and faster the better. Giving just the solutions or providing programs for machines other than HP calculators is very nice of you, thank you, but you simply forfeited the challenge, you loser ! ;-)
Next Friday I'll post the solutions and a 4-line program for a bare bones HP-71B which promptly finds out the solutions. Meanwhile be a sport and try your best. Remember, it's one thing to boast about your efficiency with RPN or RPL or whatever, and quite another to deliver the goods when challenged ... ;-)
Best regards from V.
Edited: 22 Apr 2005, 7:20 a.m. after one or more responses were posted
My brain hurts
Message #2 Posted by Gene on 20 Apr 2005, 10:39 a.m.,
in response to message #1 by Valentin Albillo
C'mon, Gene ! It's quite simple :-)
Message #3 Posted by Valentin Albillo on 20 Apr 2005, 10:48 a.m.,
in response to message #2 by Gene
In your case I'll gladly make an exception: do post a program for a TI machine, should you feel more comfortable with it.
I know you're a keen defender of TI machines, just as I am of (some) SHARP ones, so this might be your opportunity to show that they're up to the task.
Re: C'mon, Gene ! It's quite simple :-)
Message #4 Posted by Gene on 20 Apr 2005, 10:51 a.m.,
in response to message #3 by Valentin Albillo
Insults? :-)
I like the old TI machines, but I am an RPN / RPL man!
I can't imagine trying to write a program to do this on a 100-step SR-56. :-)
Of course, that's primarily because I haven't thought through the problem enough yet, I suppose!
Gene
Message #5 Posted by Valentin Albillo on 20 Apr 2005, 12:24 p.m.,
in response to message #4 by Gene
Hi again, Gene:
Gene posted: "Insults? :-)
No, why on earth would you feel insulted ? Myself, I've stated a number of times that vintage SHARP machines are every bit as good if not better than contemporary HP ones and I wouldn't feel insulted in the least if someone were to offer me using a SHARP instead of an HP. But a TI ... that's a horse (donkey ?) of a different color ... come to think of it, you have a point, my apologies.
"I like the old TI machines, but I am an RPN / RPL man!"
I'm *not*.
"I can't imagine trying to write a program to do this on a 100-step SR-56. :-)"
I don't know about the SR-56, but I've got a quick'n'dirty 41CX version in some 60 steps ... Way to go.
Now stop ranting and do write a solution, man ! :-)
SR-56 memories...
Message #6 Posted by Marcus von Cube on 23 Apr 2005, 11:17 a.m.,
My flag (re)setting algorithm will certainly not work! The most complicated problem I've ever tackled on the 56 was the solving of 3 linear equations with 3 unknowns. Because there are only 10 registers on the machine, I had to enter the constants on the right hand side of the equations 3 times (once for each unknown.)
And of course, I had to type in the whole program every time I wanted to use it...
... and a link to the HP-20S
Message #7 Posted by Karl Schneider on 23 Apr 2005, 1:37 p.m.,
in response to message #6 by Marcus von Cube
Marcus von Cube posted,
The most complicated problem I've ever tackled on the [Texas Instruments TI-]56 was the solving of 3 linear equations with 3 unknowns. Because there are only 10 registers on the machine, I had to enter the constants on the right hand side of the equations 3 times (once for each unknown.)
The HP-20S (discontinued in 2002), also has only 10 storage registers. It includes a built-in loadable keystroke program for solving an exactly-determined 3x3 set of linear equations, using Cramer's Rule.
After the program "3by3" is loaded into program memory, the user enters the 9 matrix coefficients in registers 1-9, and the "upper" result constant into register 0. The remaining two constants are placed in the stack, separated by "INPUT". "XEQ A" calculates the solution.
The program can be used to solve an exactly-determined 2x2 system by entering the system as follows:
[a11 a12 0]  [b1]
[a21 a22 0]  [b2]
[ 0   0  1]  [ 0]
A matrix can be inverted by solving for [1 0 0]T, [0 1 0]T, and [0 0 1]T in succession.
Determinants can be calculated using "XEQ D" after loading the "3by3" program.
Kind of a pain in many respects, but it's better than nothing, I suppose...
-- KS
Re: Short & Sweet Math Challenges #7: Squares !
Message #8 Posted by Larry Corrado, USA (WI) on 20 Apr 2005, 9:03 p.m.,
Valentin:
Rather than RPN or RPL, I used "whatever." Namely, Java on my Dell. Does that count? ;-)
I love my HP-25, which I used daily for 25 years. My HP-15C is beautiful, with its crisp, hi-contrast display. I love the glowing digits on my 34C... But when it comes to programming, I'll stick to Java or VB.NET.
I look forward to seeing your 4-line solution. Thanks for presenting the challange.
Ciao, Larry
Message #9 Posted by Arnaud Amiel on 21 Apr 2005, 4:40 a.m.,
This is short but dirty and slow (just over 1 hour) on the 49+. It will not work in RPN though...
<< RCLF {} 'RESULTS' STO 10. STWS BIN
1. 8. FOR I #1b I 1. + 9.
  FOR J 1. 1022.
    FOR K DUPDUP NOT ->STR TAIL OBJ-> DROP I * SWAP ->STR TAIL
          OBJ-> DROP J * + DUP
          IF FP THEN DROP ELSE 'RESULTS' STO+ END
    #1b +
    NEXT
  NEXT DROP
NEXT STOF
And it tells me that 6661661161 is the only answer.
Now I have to find an other more efficient way to do it.
Arnaud
Erratum
Message #10 Posted by Arnaud Amiel on 21 Apr 2005, 5:53 a.m.,
in response to message #9 by Arnaud Amiel
I forgot to type a SQRT (well a square root sign) just before the IF
Appart from that it works but so slowly... this is the kind of algorithm that would do well in assembly. Oh and I can't use this algorithm to go to step 2.
Arnaud
Edited: 21 Apr 2005, 6:21 a.m.
Re: Short & Sweet Math Challenges #8: Squares !
Message #11 Posted by Jeff O. on 21 Apr 2005, 6:34 p.m.,
Without looking at Larry's or Arnaud's responses (I swear!) , in case they gave the answers, I'll go out on a limb and present the following:
1. Find a 10-digit square which consists of just two different numbers, from 1 to 9 (0's not allowed)....The solution is unique.
According to my hp-42S program, that number would be 6661661161, with a square root of 81619.
According to my hp-42S program, the 10 digit squares that consist of just three different numbers are as follows:
COUNT	NUMBER	SQUARE
1      	33334 	1111155556
2      	33335   1111222225
3      	33338 	1111422244
4	33359 	1112822881
5	33989	1155252121
6	34641	1199998881
7	34827	1212919929
8	34965	1222551225
9	36361	1322122321
10	37962	1441113444
11	39388	1551414544
12	39581	1566655561
13	40204	1616361616
14	43923	1929229929
15	44623	1991212129
16	47162	2224254244
17	50235	2523555225
18	54123	2929299129
19	54335	2952292225
20	57665	3325252225
21	58167	3383399889
22	62156	3863368336
23	66515	4424245225
24	66665	4444222225
25	66667	4444488889
26	66668	4444622224
27	67485	4554225225
28	68187 	4649466969
29	68962	4755757444
30	70107	4914991449
31 	70173	4924249929
32 	72285	5225121225
33	72335 	5232352225
34	72475	5252625625
35	76478	5848884484
36	78196	6114614416
37	78541	6168688681
38	78881	6222212161
39	79162	6266622244
40	80408	6465446464
41	81346	6617171716
42	81404	6626611216
43	81813	6693366969
44	83666	6999999556
45	86478	7478444484
46	97773	9559559529
47	98336	9669968896
I was a bit distressed that I found only 47 of these, as apposed to the 48 that V. stated exist. However, upon reading his challenge, it does say at most. The group should therefore include those that have just 3 numbers listed above, plus the solution that has just 2 numbers, plus any that consist of just one number. A quick check of 111111111, 222222222, etc. with my calculator revealed that none of these are perfect squares. So the list of 47 above plus the unique solution to the first problem yields the 48 solutions to the second problem. (I hope.)
I'm quite sure that I used a very non-elegant, non-optimized, brute-force method. The program I wrote consisted of several basic parts.
1. create the 10 digit numbers by squaring all possible numbers that could create them. The maximum 10 digit number that meets the first criterion is 999999998, whose square root is 99999.99999. So no need to check anything above 99999. The minimum that satisfies the first criterion is 1111111112, whose square root is 33333.33333, so no need to check anything lower than 33334.
2. Break the 10 digit number up into 10 single digits stored in registers 1 through 10 (checking for numbers with zeroes and throwing them out along the way).
3. sort those digits in ascending order in registers 1 through 10.
4. run through registers 1 through 10 and count the number of times that two adjacent digits are not equal to each other.
5. See if the above is either 2, to solve the first problem or 3 to solve the second. If so, print out the number and the square.
6. Move on to the next number.
The program I wrote based on the above methodology was an HP-42S program. However, I developed and ran it on Free42. On my PC, my first version solved each of the problems in about 14 seconds. I then optimized the sorting and checking routines somewhat, and it solved each problem in about 9 seconds. I entered that version into a real 42S. After about 3 hours and 45 minutes I stopped it to make sure it was working correctly. It had found the first 8 solutions, and was about 2.4% of the way through the sequence of numbers. Based on that, it would have taken nearly 6 days to complete. Obviously, I chose a quite inefficient solution scheme. A different approach would be required to make it realistically soluable by a real 42S.
Edited: 25 Apr 2005, 7:16 a.m. after one or more responses were posted
Message #12 Posted by Jonathan Puvis (New Zealand) on 21 Apr 2005, 9:57 p.m.,
in response to message #11 by Jeff O.
I came up with pretty much the same algorithm (before you posted your message). I initially wrote it in Python (attached below), but my User-RPL version on the 48G ran for more than an hour after which i stopped it as the low battery warning had come one.
I could write the digit counting function in Saturn assembly to speed it up, but i'm sure there is a better algorithm for counting the digits, i just can't think of it.
#!/usr/bin/python
def count_digits(x):
  x = int(x)
  digits = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
  while x:
    digits[x % 10] = 1
    x = x / 10
  if digits[0]:
    return 99
  return sum(digits)
for x in range(33333, 99999):
  sq = x * x
  if count_digits(sq) == 2:
    print '2:', x, sq
print
  sq = x * x
  if count_digits(sq) <= 3:
    print '<=3', x, sq
HP-32S solution
Message #13 Posted by Eamonn on 21 Apr 2005, 11:32 p.m.,
Valentin,
It's been a while since you posted a S&SMC! As ever, they are quite thought provoking.
I had to have a go at writing a program for the HP-32S to solve the first problem.
The basic idea was to generate all the possible ten-digit numbers that consist of two different numbers, take their square root and test to see if the fractional part is non-zero. There are C(9,8) * 2^10 = 36864 such numbers.
My first attempt would have taken about 10 hours to generate and test all such numbers (It generated and tested about 1 number per second). I won't bother posting it.
After thinking about it a bit, I took a different approach to generating the numbers that generates and tests all of them in about 27 minutes (almost 23 numbers per second).
This second approach uses almost all the 390 bytes of memory on the HP-32S. I'm guessing that it will also run on the HP-33S - not sure if it will be much faster or slower. Perhaps someone would be willing to try it out.
A different approach is needed for the second part of the problem - if my math is correct, there are almost 5 million possibilities for a 10-digit number made up of 3 unique digits.
Anyway, here is the program that I wrote. The program can be run by hitting XEQ V. It stops and displays each solution it finds. The user needs to hit the R/S key to continue after each solution. The number of solutions found is stored in the E register. It finds one solution for the first problem (6661661161 = 81619^2).
Eamonn
LBL T   ; Test the value that is in C
RCL C
SQRT
FP
X<>0?
RTN
1
STO+ E ; Count of how many solutions were found
RCL C
STO D  ; Store most recent solution
R/S    ; Stops to display latest solution - User needs to hit R/S to continue
RTN
[CHKSUM = A889]
LBL A XEQ T RCL J STO+ C XEQ T RCL K STO+ C XEQ T RCL J STO+ C XEQ T RTN [CHKSUM = 5BA1]
LBL B XEQ A RCL L STO+ C XEQ A RCL M STO+ C XEQ A RCL L STO+ C XEQ A RTN [CHKSUM = 3AA5]
LBL C XEQ B RCL N STO+ C XEQ B RCL O STO+ C XEQ B RCL N STO+ C XEQ B RTN [CHKSUM = D82D]
LBL D XEQ C RCL P STO+ C XEQ C RCL Q STO+ C XEQ C RCL P STO+ C XEQ C RTN [CHKSUM = 1A38]
LBL E XEQ D RCL R STO+ C XEQ D RCL S STO+ C XEQ D RCL R STO+ C XEQ D RTN [CHKSUM = EEA7]
LBL V ; <---- Program Entry Point 0 STO E ; Initialize number of answers 9 STO A ; First Digit [CHKSUM = 8B6D]
LBL F RCL A 1 - x=0? ; If B will be zero, then we're done RTN ; <---- Program Exit Point STO B ; Second Digit [CHKSUM = 60AB]
LBL G 11.019 STO i 1 STO J [CHKSUM = 44BD]
LBL H ; Setting up constants used by the program 10 * 1 - STO (i) ; K(i) = 10 * K(i-1) - 1 ISG i GTO H 10.019 STO i RCL A RCL- B [CHKSUM = AF37]
LBL I ; Loop to multiply constants by (A-B) STO* (i) ISG i GTO I 1111111111 RCL *B STO C ; C is the first value to test XEQ E ; Call recursive generation of test values DSE B ; Loop on second digit GTO G DSE A ; Loop on first digit GTO F [CHKSUM = 62F8]
Re: HP-32S solution
Message #14 Posted by Arnaud Amiel on 24 Apr 2005, 3:14 a.m.,
in response to message #13 by Eamonn
It takes about 19min on the 33s that is about 33% faster.
Arnaud
Message #15 Posted by Bram on 22 Apr 2005, 7:03 a.m.,
Hi V,
1. Thanks for the challenge
2. Did you loose track? Think there already has been a #7
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=59918
3. My program is for the 32SII. After a short analysis it appeared that "only" the numbers between 31622 and 99999 are eligible for an answer.I check them all for the criteria and I break out the moment a criterion fails. That's the only speed up, so finding the answer 81619 takes several hours.
The program is for the 3 dupl. problem; if you remove the marked instructions, you get the program for the single solution problem.
LBL A ; CK=1BB7 012.5 31622 STO N LBL B ; CK=35F8 024.5 1 STO+ N RCL N x² XEQ C RCL N 99999 x>=y? GTO B STOP
LBL C ; CK=BA5C 013.5 FS? 0 PSE CF 1 CF 2 CF 3 ; <= STO R 10 ; squared number consists of 10 digits STO I LBL J ; CK=C11A 021.0 RCL R ; go strip off a single digit IP 10 / STO R FP x=0? RTN ; no zeros allowed, next number FS? 1 ; digit already encountered? GTO K ; yes STO X ; no, store it for comparison with more digits SF 1 ; digit now has encountered GTO M LBL K ; CK=CDA4 015.0 RCL X ; get first unique digit x=y? ; equal to the one in question? GTO M x<>y FS? 2 ; like before, but now for the second digit GTO L STO Y SF 2 GTO M LBL L ; CK=B38A 015.0 RCL Y x=y? GTO M x<>y ; <= FS? 3 ; <= like before, but now for the third digit GTO N ; <= STO Z ; <= SF 3 ; <= GTO M ; <= LBL N ; CK=2764 007.5 RCL Z ; <= x=y? ; <= GTO M ; <= RTN LBL M ; CK=102A 010.5 DSE I GTO J ; go to the next digit to examine RCL N ; all digits examined, so now we have an answer x² STOP RTN
total length: 119.5
; storage registers ; N number to examine ; R number² being split into digits ; X Y (Z) the digit to occur ; ; labels ; A loop through all N values ; B inner loop ; C check max diff digits in square of number N ; JKL(N) place holders ; M increment to the next digit to examine ; ; flags ; 0 set => show progression ; 12(3) keep track of new occurrance of digit
Thanks a lot, Bram !
Message #16 Posted by Valentin Albillo on 22 Apr 2005, 7:25 a.m.,
in response to message #15 by Bram
Hi, Bram:
Bram posted:
"2. Did you loose track? Think there already has been a #7 http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=59918 "
Yes, I certainly did. Though I searched my files to see what the current number should be, it seems I didn't keep a record of that particular S&SMC (#7), so I thought that #6 was the very last to date.
I've duly corrected the numbering, so that it won't be kept in the MoHP Archives section with the wrong, duplicated number.
Thanks a lot, see my post with the solutions and comments within 12 hours.
Re: Thanks a lot, Bram !
Message #17 Posted by Bram on 22 Apr 2005, 10:28 a.m.,
in response to message #16 by Valentin Albillo
Anytime Valentin, and in the meantime I rewrote my program to a more versatile one based on indexing. The marked line defines the criterion for the number of digits. Change the 3 into 2 for the first problem. Changing the comparison in the next line is for adoption to exactly x different digits or a least y different digits a.s.o.
regards,
Bram
LBL C ; CK=78F9 009.0 FS? 0 PSE STO R 9 STO i LBL I ; CK=DD00 010.5 0 STO (i) DSE i GTO I 10 ; squared number consists of 10 digits STO J LBL K ; CK=0B4E 027.0 RCL R ; go strip off a single digit IP 10 / STO R FP x=0? RTN ; no zeros allowed, next number 10 * STO i 1 STO+ (i) DSE J GTO K 10 STO i LBL J ; CK=E621 022.5 RCL (i) x#0? 1 STO+ J DSE i GTO J 3 ; <= max. number of different digits RCL J x>y? RTN RCL N x² STOP RTN
total length: 106.0
; storage registers ; N number to examine ; R number² being split into digits ; A-I&J for counting occurrences ; ; labels ; A loop through all N values ; B inner loop ; C check max diff digits in square of number N ; IJK place holders ; ; flags
Re: Third version
Message #18 Posted by Bram on 26 Apr 2005, 4:44 p.m.,
in response to message #17 by Bram
Hi Valentin, once more....
My second program was more versatile, but much slower than my first one. I tried to speed up my original program by squeezing the inner part to a minimum number of instructions. In only 15 lines (starting at ENTER) I test all criteria and you may be interested in how I use "conditional comparison" to get this done.
I hope things are clear enough by my comments in the program.
31622	; smallest root of ten digits number minus 1
STO N
1
STO+ N
RCL N
x²
XEQ C	; examine all ten digits squares
RCL N
99999
x>=y?
GTO B
STOP
LBL C ; CK=AB00 015.0 FS? 0 ; wish to see progression? PSE ; yes, show square that's going to be examined STO R 0 STO X ; clear x Y Z on behalf of the three different digits STO Y STO Z ; <= 10 ; squared number consists of ten digits STO I LBL J ; CK=9B2F 037.5 RCL R ; go strip off a single digit IP 10 / STO R FP x=0? RTN ; no zeros allowed => next number ENTER ; put the digit to examine into Y for comparisons x<>X ; save it in X and get former value from X x#0? ; if former value was 0, we have a new digit; goto M for next digit x=y? ; if equal, we have a duplicate digit; goto M for next digit GTO M x<>X ; digit is a new, second one; restore X with original contents ; and get back the digit to examine into X x<>Y ; same as before; check against 2nd distinct digit that has occurred x#0? x=y? GTO M x<>Y ; <= C x<>Z ; <= L x#0? ; <= E x=y? ; <= A GTO M ; <= R these lines when checking for just two different digits RTN ; we get to this point when a fourth digit is reached => next number LBL M ; CK=102A 010.5 DSE I GTO J ; go to the next digit to examine RCL N ; all digits examined, so now we have an answer x² ; proudly show the result STOP ; and allow the user to see it RTN ; continue with next number
total length: 100.0
; storage registers ; I loop counter for ten digits ; N number to examine ; R number² being split into digits ; X Y (Z) the digit to occur ; ; labels ; A loop through all N values ; B inner loop ; C check max diff digits in square of number N ; J place holder ; M increment to the next digit to examine ; ; flags ; 0 set => show progression
regards, Bram
Message #19 Posted by Olivier De Smet on 22 Apr 2005, 9:51 a.m.,
Here is a quick hack for an HP86B (with advance prog module)
10 l=0 @ o=3 @ t=TIME  @ FOR n=33333 TO 99999 @ IF o=10 THEN o=0 @ GOTO 60
20 k=1 @ SFLAG "" @ m=n*n @ SFLAG m MOD 10 @ m=m\10 @ FOR j=2 TO 10 @ b=m MOD 10 @ IF b=0 THEN 60
30 IF FLAG (b) THEN 50
40 IF k=3 THEN 60 ELSE SFLAG b @ k=k+1
50 m=m\10 @ NEXT j @ l=l+1 @ DISP l,n,n*n
60 o=o+1 @ NEXT n @ DISP "Fini:";TIME -t @ END
run 1 33334 1111155556 2 33335 1111222225 3 33338 1111422244 4 33359 1112822881 5 33989 1155252121 6 34641 1199998881 7 34827 1212919929 8 34965 1222551225 9 36361 1322122321 10 37962 1441113444 11 39388 1551414544 12 39581 1566655561 13 40204 1616361616 14 43923 1929229929 15 44623 1991212129 16 47162 2224254244 17 50235 2523555225 18 54123 2929299129 19 54335 2952292225 20 57665 3325252225 21 58167 3383399889 22 62156 3863368336 23 66515 4424245225 24 66665 4444222225 25 66667 4444488889 26 66668 4444622224 27 67485 4554225225 28 68187 4649466969 29 68962 4755757444 30 70107 4914991449 31 70173 4924249929 32 72285 5225121225 33 72335 5232352225 34 72475 5252625625 35 76478 5848884484 36 78196 6114614416 37 78541 6168688681 38 78881 6222212161 39 79162 6266622244 40 80408 6465446464 41 81346 6617171716 42 81404 6626611216 43 81619 6661661161 44 81813 6693366969 45 83666 6999999556 46 86478 7478444484 47 97773 9559559529 48 98336 9669968896 Fini: 108.019 ¨
In fact as 0 isn't allowed only integer from 33333 to 99999 are tested and not ending with 0.
The given program is for the second problem (which include the first). Need 1h50 on real hardware to find all solutions. Change line 40 with '40 IF k=2 ...' for the first problem.
Thanks again for the challenge.
Olivier
Edited: 22 Apr 2005, 9:57 a.m.
Message #20 Posted by Olivier De Smet on 22 Apr 2005, 11:16 a.m.,
in response to message #19 by Olivier De Smet
A better solution for the first problem:
list
10 t=TIME
20 FOR i=0 TO 511 @ a=1000000000+VAL (DTB$ (i)) @ b=VAL (DTB$ (511-i))
30 FOR j=1 TO 9 @ FOR k=1 TO 9 @ m=j*a+k*b @ IF FP (SQR (m))=0 THEN DISP SQR (m),m
40 NEXT k @ NEXT j @ NEXT i @ DISP "Fini:";TIME -t @ END
 517068
run
 81619                6661661161
Fini: 19.118
Just 20 mins for finding the value, but need the I/O module.
Olivier
Message #21 Posted by J-F Garnier on 22 Apr 2005, 11:26 a.m.,
in response to message #20 by Olivier De Smet
Hi Olivier,
I was just about to post a similar solution for the 71B. You can improve this solution by noticing that only numbers ending by 1, 4, 5, 6 or 9 can be a square number. But I didn't find how to solve the 3-digit problem with this approach.
J-F
Message #22 Posted by Olivier De Smet on 22 Apr 2005, 11:35 a.m.,
in response to message #21 by J-F Garnier
Yes I know but searching to eliminate such non solution is too costly in time :)
A better one :
list
10 t=TIME
20 FOR i=0 TO 511 @ a=1000000000+VAL (DTB$ (i)) @ b=VAL (DTB$ (511-i)) @ FOR j=1 TO 9 @ m=j*a @ FOR k=1 TO 9 @ m=m+b @ IF FP (SQR (m))=0 THEN DISP SQR (m),m
30 NEXT k @ NEXT j @ NEXT i @ DISP "Fini:";TIME -t @ END
 517065
run
 81619                6661661161
Fini: 15.199
Only 16 mins :)
Olivier
Message #23 Posted by J-F Garnier on 24 Apr 2005, 11:00 a.m.,
in response to message #22 by Olivier De Smet
A slighly improved version of Olivier's solution, for the HP-71B and using the BSTR$ function from the Math module:
10 T=TIME
15 OPTION BASE 1 @ DIM F(5)
16 DATA 1,4,5,6,9
17 READ F()
20 FOR I=0 TO 511 @ A=VAL(BSTR$(I,2))*10+1 @ B=VAL(BSTR$(511-I,2))*10
30 FOR J=1 TO 5 @ M=F(J)*A @ FOR K=1 TO 9 @ M=M+K*B @ IF FP(SQRT(M))=0 THEN DISP SQRT(M),M
40 NEXT K @ NEXT J @ NEXT I @ DISP "Fini:";TIME-T @ END
 81619                6661661161
Fini: 45.77
Running on Emu71 using a 1.7GHz processor.
J-F
Message #24 Posted by Olivier De Smet on 25 Apr 2005, 3:02 a.m.,
in response to message #23 by J-F Garnier
As I told you I don't need to optimize, my programm need only 15.2 sec running on an HP86B emulator on a 1.8Ghz pentium M :)
But you're right it's faster like this :
list
10 t=TIME  @ OPTION BASE 0@ DIM f(4)
20 f(0)=1 @ f(1)=4 @ f(2)=5 @ f(3)=6 @ f(4)=9
30 FOR i=0 TO 511 @ a=VAL (DTB$ (i))*10+1 @ b=VAL (DTB$ (511-i))*10 @ FOR j=0 TO 4 @ m=a*f(j) @ FOR k=1 TO 9 @ m=m+b @ IF FP (SQR (m))=0 THEN DISP SQR (m),m
 516894
run
 81619                6661661161
Fini: 8.486
Only 8.846 sec :)
Olivier
Edited: 25 Apr 2005, 6:02 a.m.
Message #25 Posted by Olivier De Smet on 22 Apr 2005, 11:39 a.m.,
For 3 digit as someone said it there is too much candidates, so the reverse approach should be better I think because you only have to test (99999-33333) candidates.
For 2 digits it's the cost of the test which is important as you have either 66666 or 512*9*9 candidates.
Olivier
Hi, Jean-Franēois !
Message #26 Posted by Valentin Albillo on 22 Apr 2005, 11:46 a.m.,
Hi, J-F:
Your wonderful Emu71 HP-71B's emulator runs my solution program for the HP-71B in under 40 seconds !
By the way, did you get to see my latest HP-71B articles published in Datafile ? All of the featured programs were created with the help of your Emu71, and it runs them like a charm. I do include footnotes recommending both your emulator and Hrastprogrammer's one for the 48/49, so that readers can know that they can try the programs and fully enjoy them themselves.
The ones featured in the latest Datafile issue are an extremely good test of your emulator's performance, as they make use not only of the emulated basic 71B itself, but also of the emulated Math and HP-IL ROMs as well, and it does certainly pass the taxing ordeal with flying colors, to say the least !
Re: Hi, Valentin
Message #27 Posted by J-F Garnier on 24 Apr 2005, 9:52 a.m.,
in response to message #26 by Valentin Albillo
Unfortunatly no, I (still) didn't subscribe to Datafile, shame on me ...
J-F
Message #28 Posted by Marcus von Cube on 22 Apr 2005, 1:36 p.m.,
This is a solution for the HP 42S and HP 41C. [Edited]
Usage:
Enter the number of allowed different digits (2 or 3) in X and XEQ "SQ10". After the 33333 is displayed you have to press R/S (You can correct the starting number, if you like.)
If you enter a number >9, XEQ "SQ10" will just run the comparison engine (LBL 00) and show "OK" if the criterion is met. You need to store the number of digits manually in R02 before you can use the program this way.
LBL "SQ10"   Main entry point
0
STO 09
Rv
9
X<>Y
X<=Y?
GTO 10
XEQ 00
RCL 00
FC? 00
RTN
"OK"
AVIEW
RTN
Now comes the checking engine. It works on flags 0-9 which are all set in the beginning and cleared indirectly for each corresponding digit. The reset operations are counted in R00. If the count reaches the limit in R02, the check has failed and flag 0 will be cleared. (This is done at no cost, if a "0" digit is found.) A cleared flag 0 stops the loop.
R09 counts the total number of calls for statistical purposes.
LBL 00
VIEW ST X
SF 00
SF 01
SF 02
SF 03
SF 04
SF 05
SF 06
SF 07
SF 08
SF 09
0
STO 00
1
STO+ 09
Rv                RDN for HP 41
Rv
LBL 01 digit loop STO 01 10 MOD FC?C IND ST X this does the flag testing and clearing! GTO 02 this digit is already counted RCL 00 get count RCL 02 max # of different digits allowed X<=Y? CF 00 FC? 00 RTN too many different digits 1 STO+ 00 count LBL 02 get next digit RCL 01 10 / IP INT for HP 41 X!=0? any digits left? GTO 01 RTN
LBL 05 find smallest digit from flags works only after a passed check! RCL 00 RCL 02 - X=0? maximum # of digits reached? GTO 06 look for smallest Rv 1 return 1, because less than the RTN allowed number of digits were present
LBL 06 1 + FS? IND ST X GTO 06 RTN
This is the controlling loop. It starts at 33333+1 but it does not try each and every number up to 99999. When the left most 4 digits do not pass the check, there is no need to try any number that would result in the same 4 digits. I simply construct a number with the next higher value and get the SQRT from it:
If guess² == p,qrs,tuv,wxy. then new guess = SQRT( (p,qrs.+X)*10e6 + Y11,111. )
p,qrs+X is determined by adding 1 in a loop and checking the resulting 4 digit number until the check passes. Y is the smallest digit found in p,qrs+X by the check routine.
A similar trick is used to skip guesses when the first 3 digits fail the check.
(The following is awful spaghetti code and I'm willing to streamline it when I have time.)
LBL 10
STO 02            store # of allowed digits
0
STO 05
STO 06            scratch registers for first 3 to 4 digits
33333             the loop starts with this initial guess
STOP              correct the initial guess at will
                  (The loop starts with this number + 1!)
LBL 11 STO 03 store first guess - 1
LBL 12 1 STO+ 03 increment guess 999999 final value RCL 03 X>Y? GTO 20 no more numbers to try X^2 STO 04 store result to check (for later) 1E6 / IP first 4 digits (INT for HP 41) x<>Y RCL 05 first 4 digits from last loop X!=Y? changed? GTO 13 check and find best next guess RCL 04 squared guess XEQ 00 check it FC? 00 GTO 12 failed, try next CLD OK, show result RCL 03 RCL 04 BEEP STOP GTO 12 back to main loop
LBL 13 find the next guess quicker by checking 1 the first 3 or 4 digits only - STO 05
LBL 14 1 STO+ 05 new value for first 4 digits RCL 06 first 3 digits (saved) RCL 05 first 4 10 / IP X=Y? GTO 19 the first 3 are the same as before
LBL 15 STO 06 new value for first 3 XEQ 00 check FS? 00 GTO 16 first 3 digits are OK, must try first 4 RCL 06 1 + GTO 15
LBL 16 new first 4 digits from first 3 digits RCL 06 10 * XEQ 05 find smallest digit from flags + STO 05
LBL 19 check the first 4 digits RCL 05 XEQ 00 check FC? 00 GTO 14 check failed, try next RCL 05 compute new guess 10 x XEQ 05 find smallest digit + 1E5 x 11110 + SQRT IP GTO 11 restart with new guess
LBL 20 finis CLD CLX END
See next post for some statistics.
Edited: 23 Apr 2005, 2:33 p.m. after one or more responses were posted
Some Statistics for the above
Message #29 Posted by Marcus von Cube on 23 Apr 2005, 11:09 a.m.,
in response to message #28 by Marcus von Cube
Performance:
The 42S took about 90 minutes to find the 2 digit solution. My 41CX arrived after 4 hours and 10 minutes.
The number of checks performed was 4487 until the first solution (81619) and 6625 total. (These numbers were computed before I've made my last changes, but the results should be similar.)
Anybody for a faster check routine? It looks like the loop over the digits takes most of the computing time.
Re: Some Statistics for the above
Message #30 Posted by Marcus von Cube on 24 Apr 2005, 8:28 a.m.,
in response to message #29 by Marcus von Cube
With the current version I could reduce the time and number of calls further:
3771 calls to the check routine and 75 minutes to solve the 2 digit problem on a real unmodified 42S. The 41C took 3:45 minutes. (It's funny to watch the flags toggle in the display :-) )
The total number of calls to the checking routine was 5140. This will be significantly higher for the three digit problem, because less numbers can be ruled out beforehand based on the first 4 digits.
Message #31 Posted by Arnaud Amiel on 23 Apr 2005, 6:47 p.m.,
As stated above, I believed that assembly was more suited to this problem so I gave it a try. The 49G and 49g+ are the only calcs to have assembly available out of the box so I tried on the 49g+. The program below (non optimised) solves question 2 in 43s. A 49g would take 1min 43s. It is easy to port it on the 48 where it should run as fast as on a 49 (or half speed on the SX).
Here is the program
SAVE
SETDEC
LC 33332
R1=C.A
*NextNumber C=R1.A C+1.A SKIPNC { P=0 SETHEX LOADRPL } R1=C.A C=0.W C=R1.A CSL.W CSL.W CSL.W A=C.W GOSBVL =SPLITA C=B.W D=C.W C=A.W GOSBVL =MULTF GOSBVL =PACK C=0.W C=A.M CSR.W CSR.W CSR.W CSR.W CSR.W
P=10 A=0.S B=0.S D=0.S *TestNumber P-1 GOC GoodNumber CSRC ?C=0.S GOYES NextNumber ?A#0.S { A=C.S GOTO TestNumber } ?A=C.S GOYES TestNumber ?B#0.S { B=C.S GOTO TestNumber } ?B=C.S GOYES TestNumber ?D#0.S { D=C.S GOTO TestNumber } %remove for question 1 ?D=C.S GOYES TestNumber %remove for question 1 GOTO NextNumber
*GoodNumber A=0.W A=R1.A ASRC ASRC ASRC ASRC ASRC ASRC A+4.A GOSBVL =PUSH% SAVE SETDEC GOTO NextNumber
As usual archive before playing with assembly
Arnaud
PS: If you want I can send you the compiled program for 48 or 49 by email
[LONG] S&SMC #8: My original solutions, comments and curiosities !
Message #32 Posted by Valentin Albillo on 25 Apr 2005, 5:13 a.m.,
Hi all,
Thanks to all of you interested in my S&SMC #8 and most specially to those who provided such ingenuous and elegant solutions for such a variety of HP calcs and computers, we really saw a lot of interesting techniques being used here for the one and only purpose: find the solutions and find them fast. Congratulations to all of you, I *really* feel most satisfied with your contributions !
As promised, this is my original, 4-line solution for the HP-71B:
10 C=0 @ FOR N=33334 TO 99999 @ M$=STR$(N*N) @ IF POS(M$,"0") THEN 40 ELSE T$=M$[1,1]
20 FOR I=2 TO 10 @ IF POS(T$,M$[I,I]) THEN 30 ELSE IF LEN(T$)=3 THEN 40 ELSE T$=T$&M$[I,I]
30 NEXT I @ C=C+1 @ DISP N;M$,T$
40 NEXT N @ DISP "OK:";C;"found"
Calling it produces the 48 solutions, displaying the number, its square, and the distinct digits it consists of:
>CALL
33334 1111155556 156 33335 1111222225 125 33338 1111422244 142 33359 1112822881 128 33989 1155252121 152 34641 1199998881 198 ... 81404 6626611216 621 81619 6661661161 61 <- only *two* different digits, the solution to the first part 81813 6693366969 693 83666 6999999556 695 86478 7478444484 748 97773 9559559529 952 98336 9669968896 968
OK: 48 found
It takes 3 min 28 sec when run under Emu71 in a 1.4 Ghz PC. The program searches all numbers which generate 10-digit squares fulfilling the conditions. As no 0's are allowed, the smaller possible square would be 1111111111, so we begin the search at SQR(1111111111) rounded to the nearest integer, which is 33334, and go on searching till SQR(9999999999), which comes out to 99999. We square each number in turn and convert the result to a string. The first POS then immediately discards numbers having a "0" anywhere. Then we keep on extracting individual digits which are added to an auxiliary string, using POS to detect repetitions (in which case we don't add the digit again) and LEN to see if there are more then 3 distinct digits already collected, in which case we forfeit further processing of this number and go instead to check the next candidate.
However, this is not the fastest way to proceed because the HP-71B is optimized for numerical computations and string processing is relatively slow. So I originally came out instead with this other version, which uses flags to register which digits have been used:
10 C=0 @ FOR N=33334 TO 99999 @ M=N*N @ CFLAG ALL @ P=0
20 FOR I=1 TO 10 @ D=MOD(M,10) @ IF NOT D THEN 50 ELSE M=M DIV 10
30 IF FLAG(D) THEN 40 ELSE IF P=3 THEN 50 ELSE SFLAG D @ P=P+1
40 NEXT I @ C=C+1 @ DISP N;N*N
50 NEXT N @ DISP "OK:";C;"found"
It works the same, only using flags instead of strings. Each candidate number is decomposed into its constituent digits. If the digit is a 0, we skip to the next candidate, else a flag is set corresponding to the digit. If more than 3 flags have alrady been set, no further digits are isolated but we go instead to test the next candidate. This version finds the exact same solutions but it takes just 72 seconds (under Emu71), i.e., it's 3 times faster than the string version. A real HP-71B takes much longer of course, but it's a real beauty to see the display's flag indicators making a frantic dance while the program runs !
In both versions, changing the "3" to any other single digit N (1-9) would find squares made up of N distinct digits. For instance, with N=2, it produces 6661661161, the only 10-digit square consisting of just two different digits, 1 and 6 in this case. Also, you can search for 12-digit squares instead, say, by simply changing the search limits to 333334 and 999999 respectively, and by changing the limit of the I loop to 12. This can be automated by simply creating a new, generalized version that asks the user for the number of digits and maximum different values, like this:
 1 INPUT "# Digits (1-12) = ";U @ INPUT "# Diff. val. (1-9) = ";V
10 C=0 @ FOR N=INT(SQR((10^U-1)/9)) TO INT(SQR(10^U-1)) @ M=N*N @ CFLAG ALL
20 P=0 @ FOR I=1 TO U @ D=MOD(M,10) @ IF NOT D THEN 50 ELSE M=M DIV 10
30 IF FLAG(D) THEN 40 ELSE IF P=V THEN 50 ELSE SFLAG D @ P=P+1
Let's try it ! To find the five 5-digit squares consisting of at most 2 different values:
>RUN
# Digits (1-12) = 5 [ENTER] # Diff. val. (1-9) = 2 [ENTER]
109 11881 173 29929 212 44944 235 55225 264 69696
OK: 5 found
While to find the thirty 12-digit squares consisting of at most 3 different values:
>RUN
# Digits (1-12) = 12 [ENTER] # Diff. val. (1-9) = 3 [ENTER]
333334 111111555556 333335 111112222225 333338 111114222244 333359 111128222881 333858 111461164164 363639 132233322321 387288 149991994944 461761 213223221121 492162 242223434244 505525 255555525625 515415 265652622225 586893 344443393449 649788 422224444944 658357 433433939449 664388 441411414544 665908 443433464464 666515 444242245225 666665 444442222225 666667 444444888889 666668 444446222224 682908 466363336464 782104 611686666816 805262 648446888644 818333 669668898889 828667 686688996889 834386 696199996996 869924 756767765776 939938 883483443844 974417 949488489889 994836 989698666896
OK: 30 found
The 'flags' version also has the added advantage that it translates very easily to RPN machines with little or no alpha capabilities, such as the HP-41C or HP-15C. For instance, here's the translated version for an HP-41CX, a meager 46 steps:
01 *LBL "SQ3"	16  STO 04	31  GTO 04
02  CLX		17   10    	32 *LBL 05
03  X<>F	18  STO 05 	33   1
04  CF 08	19 *LBL 01	34  ST+ 02
05  CF 09	20  RCL 03 	35   1E5
06  RCLFLAG	21  INT      	36  RCL 02
07  STO 01	22   10   	37  X#Y?
08  33334	23  ST/ 03	38  GTO 00
09  STO 02	24  MOD         39  STOP
10 *LBL 00	25  X=0?  	40 *LBL 04
11  X^2		26  GTO 05    	41  DSE 05
12  STO 03	27  FS? IND X	42  GTO 01
13  RCL 01	28  GTO 04  	43  RCL 02
14  STOFLAG	29  SF IND X	44  X^2
15  .003	30  ISG 04   	45  VIEW X
                                46  GTO 05
It runs under the V41 emulator in 72 min (a real HP-41CX would take a lot longer) to produce all 48 solutions, and again, it's a joy to see all those flag indicators frantically turning on and off:
[R/S]
1111155556 1111222225 ... 9559559529 9669968896
For practical reasons and in order to to make it accessible to most HP calculators, this challenge specifically addressed 10-digit squares, but if you feel like it there are marvels out there waiting to be discovered, here are some examples:
    10099510939154979751^2 = 102000121210111101102120011101220022001 (39 digits, all 0,1,2)
557963558954625926861^2 = 311323333121312322332133323111223321313321 (42 digits, all 1,2,3)
675754811056988742949784^2 = 456644564666666555445565455644644555565545646656 (48 digits, all 4,5,6)
Actually, even the 48-item list of solutions for the original challenge holds a number of very interesting results upon close inspection, such as these beautifully-patterned squares:
  1111155556  ( 11111-5555-6    )
  1111222225  ( 1111-22222-5    )
  1616361616  ( 16-16-36-16-16  )
  2929299129  ( 29-29-29-91-29  )
  4444222225  ( 4444-22222-5    )
  4444488889  ( 44444-8888-9    )
  5252625625  ( 52-52-625-625   )
  6617171716  ( 66-17-17-17-16  )
Thanks for your interest in this humble S&SMC #8, hope you enjoyed it, and
Message #33 Posted by Tizedes Csaba [Hungary] on 27 Apr 2005, 7:33 a.m.,
:) Err, I missed it...! Thanks for the challenge! Csaba
You're welcome, Csaba ! [N.T.]
Message #34 Posted by Valentin Albillo on 27 Apr 2005, 9:30 a.m.,
in response to message #33 by Tizedes Csaba [Hungary]
