Re: HP19BII Manual Message #2 Posted by Vieira, Luiz C. (Brazil) on 22 Apr 2005, 7:32 a.m., in response to message #1 by Kevin
Hi, Kevin;
some time ago (long...) I downloaded the available HP19BII manuals at the HP site for calculators. At that time, only Portuguese and Spanish versions were available to download, and I still have both of them. The problem is that both are pdf docs generated from scanned images, so they are somehow big: the Portuguese version is about 9MBytes long and the Spanish version is about 24MBytes long (yeap, no missing dot...). I am almost sure they can still be downloaded from the HP site, but I cannot find the link I had for them. I tried a search but did not find anything.
Another fact: the HP17BII+ manual (currently available) points out many financial ressources that are common for both models, so you can use many of the HP19BII features by reading the HP17BII+ manual, instead. What I remember by heart:
the HP17BII+ has no graphics capabilities;
the HP17BII+ has no trigonometrics and no angle mode;
the HP17BII+ has no currency conversion feature;
access to ALPHA characters is different in both models.
There are others, but these I guess are the main issues.The link below points to the HP17BII+ english manual:
http://h10032.www1.hp.com/ctg/Manual/bpia5321.pdf
Hope this helps a bit.
Luiz (Brazil)
