Re: HP25 PROBLEM Message #2 Posted by Larry Corrado, USA (WI) on 21 Apr 2005, 4:33 p.m., in response to message #1 by JULIO PONCE
Julio:
I, too, have used an HP-25 since 1976. I would sometimes get a flashing display, and it seems to have happened when the battery terminals were not making contact with the terminals in the calculator. Some NiCds that I used had flatter tips, which made it harder to make contact.
Of course, I assume you have the "S" spring is in place at the base of the batteries and that the polarity is correct.
Hope this is helpful.
Larry
