Re: Will overclocking a 49g+ lessen the skipped key problem? Message #2 Posted by Raymond Del Tondo on 20 Apr 2005, 2:35 p.m., in response to message #1 by J.C. Boco
Maybe you could check comp.sys.hp48 about this topic;-)
My answer is: Overclocking alone doesn't solve the problem,
because missing keystrokes álso happens when the calc goes
from lite sleep to travelling speed.
This is a design flaw. I don't know if this will ever be solved.
You have several options:
- type slower while carefully watching the display
- miss keystrokes
- buy an HP-48
However, VPN (as a 49g+ fan) might have another answer...
Raymond
