Re: Problem with GX Message #3 Posted by Karl Schneider on 18 Apr 2005, 8:31 p.m., in response to message #1 by Raj
Raj --
Before you accept VPN's advice, consider the following:
I assume that you mean a HP-48GX. It may show stack-level identifiers 1, 2, 3, and 4 and a right-justified "0.000" (or any other value) in Level 1 when turned on, if that is what was in the stack.
To turn the 48GX off, press the right-arrow (green) shift key, followed by "ON".
-- KS
