Re: "Invalid card data" 48sx Message #5 Posted by James M. Prange (Michigan) on 18 Apr 2005, 4:07 p.m., in response to message #1 by KWK
Assuming that the card is good and has a good battery, just STO any variable to the port; use port 1 if the card is in slot 1, or port 2 if the card is in port 2. If that doesn't fix the problem, then something is wrong with either the card or the 48SX itself.
Okay, more specifically, if the card is in slot 1, then try:
0 :1:A STO :1:A PURGE
Or if it's in slot 2, then try:
0 :2:A STO :2:A PURGE
Regards, James
Edited: 18 Apr 2005, 4:25 p.m.
