Re: Hp 65 & 67 Keyboards Message #3 Posted by Tony Duell on 15 Apr 2005, 6:07 a.m., in response to message #1 by Howard
The PCBs are totally different between the 65 (which uses the classic-series anode and cathode driver chips) and the 67 (which is a Woodstock at heart).
The key contact strips, spot-welded to the PCB are the same between the 2 models. But fixing them onto the 65 PCB is decidedly non-trivial. It is possible to solder them, but IMHO the keys never feel right after doing that.
