Re: VB runtime Message #2 Posted by Mike T. on 13 Apr 2005, 5:46 p.m., in response to message #1 by Mike (Stgt)
The directory path you found does indeed exist on my system - but isn't in my code, so I can only guess that the Visual BASIC compiler includes the path to %windir%\system32 as some sort of shortcut, possibly to the VB runtime..?
I think the problems you have had are related to the use in some locales of a comma as a decimal delimiter, though I am a little confused as you do not get a type mismatch error - I have to confess that I was naive enough to presume that a number in Visual BASIC was just a number and the possibility that Visual BASIC itself would format numbers using commas depending on the users' locale just didn't occur to me!
Mike T.
