Re: HP-16C Programing Message #10 Posted by Vieira, Luiz C. (Brazil) on 6 Apr 2005, 3:20 a.m., in response to message #9 by GWB
Hi Gerson, guys;
Except for the four arithmetic basic ones (+, -, × and ÷), the only arithmetic functions that work in floating point mode (actual HP16C) are square root and reciprocal (1/x). Also, number entry, stack manipulation and programming work as well. All of the integer-number related functions (bit manipulation, boolean operators, double-precision, etc.) are disabled in floating-point mode. If I am not worng, the only function disabled in integer mode operation is the reciprocal.
Cheers.
Luiz (Brazil)
Edited: 6 Apr 2005, 6:15 a.m.
