Re: Inside my 97 Message #5 Posted by Arnaud Amiel on 27 Mar 2005, 4:29 p.m., in response to message #4 by Erik Wahlin
I found where the plastic bit came from:
It is a post that keeps the printer ribbon cable in place on the printer chassis. There are 4 others so I believe I can live without it, what is more it is hard to glue something so tiny there.
As for the printer, when I move the head out of the "park" position, as soon as I turn the calc on, it moves back. But there is no sign of the motor starting otherwise.
Paper is feeding normally when the printing head is moving as described above.
So it looks like the calculator does not detect that it has paper. I will look a bit more into this and hope it is nothing to do with some blown electronics.
Thanks for your help,
Arnaud
