Re: What's with the homepage hiccups? Message #5 Posted by Thomas Okken on 25 Mar 2005, 7:48 a.m., in response to message #1 by deleted
There is a little snippet of JavaScript code at the bottom of the home page -- it sounds like that is what's causing the reloads. Try turning off JavaScript and see if that makes the problem go away... I don't see anything wrong with this code, but then again, JavaScript is a bit of a black art sometimes.
<SCRIPT language="JavaScript">
setTimeout ("unFrameMe()", 1000);
function unFrameMe() {
if (self.parent.frames.length != 0)
self.parent.location="http://www.hpmuseum.org/"
// --> </SCRIPT>
(Note: I had to mess up the opening comment delimiter so that it doesn't become an actual comment in this message -- looks like a bug in the forum's submission handling code. Not that that has anything to do with anything...)
