Re: HP 9825B printer connection, parallel port Message #2 Posted by Thomas Okken on 25 Mar 2005, 11:24 a.m., in response to message #1 by Stephan
IIRC, the HP's I/O interface is HP-IB, while the printer has a standard parallel printer port. On the printer side, they use the same type of plug, but it's not the same bus -- you have more to do than just figuring out which pins to connect, I'm afraid!
There are companies that sell HP-IB to Centronics converters. Just Google for HP-IB (or IEEE-488) and Centronics and you'll find several.
- Thomas
