Re: attaching a routine to the 'ON' key? Message #5 Posted by Eric Lundgren on 18 Mar 2005, 1:24 a.m., in response to message #4 by VPN
Aha! Ok, TURBO is a system recognized command! Yes, I succeeded by an identical method.
<< OFF ON C124S >> STO 'STARTOFF' 101.3 ASN
**also** interesting, I found that << ON c124s >> instead will keep the calculator from turning off! This may be convenient during exams...
So far, it is performing very well.
Is TURBO clockspeed faster than the C124S routine? How is battery life for you?
Also, do you think it will significantly reduce life of the calculator?
Thank you again VPN, you have been very helpful.
Eric
