Re: cranky HP95 Message #2 Posted by Tony Duell on 8 Mar 2005, 6:18 a.m., in response to message #1 by David C. du Four
Do you mean an HP95C? The really rare one?
I have repaired one (I don't own one, I hasten to add), and I have a reverse-engineered schematic (available, as ever, from HPCC).
My hope is that your problem is power-supply related. I assume you have a known-good battery pack in there (The 95C has the same protection circuit as the other topcats, but like other topcats, it only works when the machine is on. The 95C would therefore seem to suffer from the same RAM-killing problem as the 25C and 33C, etc). It might be something as simple as a dried-up capacitor
A worse possibility, of course, is ROM problems (if the printer driver code is screwed up, then the processor could go crazy when it tries to use the printer). The bad news is that these ROMs were only used in the95C, so finding replacements is impossible.
