RAW and PGM files for HP-41 Message #1 Posted by Michel Beaulieu on 4 Mar 2005, 9:25 p.m.
Hi! I found a HP-IL card and install it on a old computer. I use "TANS41" to work with the card. After some time i finally get use to it. Now i want to transfer files on the HP museum 41 library. I try to transfer RAW files but the program don't like this file format... If i use PGM format file, transfer is great. I also try HEX file format and nothing works either.
Is there an utility to translate RAW files to PGM tans41 file format?
What is the program to use for transfering directly RAW files to the HP-41?
Is it possible to translate text files containing HP-41 program into a "uploadable" format to the HP-41? A lot of files in the HP museum library don't have a RAW or HEX files format.
Is there other format of HP-41 files on the net; where?
Is there other program for transfering files using the card i just found in a scrap box!
As you can see, i'm very interest in this card because now i can access a lot of programs on the net without keying them slowly on the HP-41... :-)
Thanks...
Michel
