This is not good... Message #2 Posted by Randy on 1 Mar 2005, 7:38 p.m., in response to message #1 by Marx Pio
FWIW, a 42S should consume approximately 2 ma with a key down, 300 ua in operation and about 5 to 10 ua in power down.
With daily use, a set of batteries should last several years in a Pioneer. There are two possible explanations for your problem:
1) Internal corrosion causing the high power consumption.
2) A bad processor.
For 1) There is one solution: Clean it.
For 2) There is one solution: The replacement of the logic board due to the construction methods used by HP (tape automated bonding). You can't replace the processor, just get yourself a complete replacement logic board from another 42S. Many times more easily said than done I'm afraid.
Edited: 1 Mar 2005, 7:44 p.m.
