Re: HP-67 display trouble: Help! Message #2 Posted by Tony Duell on 26 Feb 2005, 5:46 a.m., in response to message #1 by Albert
The 'g' segment (the one in the middle, used for the -ve sign) has a separate current control circuit, which is pair of transistors in the corner of the logic board. That, in turn is controlled by a resistor on the keyboard/display board.
Bad contacts between the keyboard/display and the logic board can cause this. Since you've just taken the machine apart to repair the reader, I would check the pins between the 2 boards carefully.
