Re: Triangle program hp32sII Message #2 Posted by bill platt on 24 Feb 2005, 5:07 p.m., in response to message #1 by Norm Pageau
Hi Norm,
You can directly translate 11c programs to 32sii. Just change the registers from numbers (0 1 2 etc through 0.9) to letters (A B C etc through Z).
If you use the indirection feature of the 11c, the 32sii is compatible there, to, but is named i and (i) instead of I and (i) respectively. 32sii has slightly enhanced indirection capabilities; yet everything that works on the 11c will work (and the same way) on the 32sii.
I hope this helps. If you need more specific help, let me know by a specific example.
Bill
