Re: hp49g+ and SYSPRL Programming Message #3 Posted by Tim Wessman on 24 Feb 2005, 3:09 a.m., in response to message #1 by Eddie Shore
Yes. There is a built in compiler named MASD. It requires a library named Extable that has the tables of the named pointer. However, the best way to use it is to download and install Emacs. In that package, there is an extable2 (even more stabel romptrs) Sdiag (stack diagrams, help, documents, etc) the emacs library itself(offers autocompletion, searching of memory, templates, macros,etc). Then download a program called Nosy (decompiles and extracts romtrs while editing in emacs) The emacs zip has a nice documentation explaining its advanced features. All are at hpcalc.org
These 4 tools give you everything you need. I actually PREFER programming on the calculator. It is really easy. I program more on the computer now though, since my program is split over 3 libraries--one weighs in at 87K, one at 67K, other at 5K. They are just too big to work on in calculator anymore. However for quick program writing I most often will do it on the calcuator because it is so easy to test.
TW
