Re: AC Adapter for HP 9114B Disk Drive Message #5 Posted by Diego Diaz on 20 Feb 2005, 7:32 p.m., in response to message #4 by Mutsch
Hi again,
The (so-called) adapter/charger, is nothing but a simple transformer (8v 3VA nominal secondary specs.)
So you *MUST* have the "Rechargable battery pack" (88014A or B) fully charged to operate the drive.
The 9114 takes its supply from the battery. Transformer (82066B) just re-charge the battery while the drive is not spinning.
Hope this helps.
Diego.
