Re: A request...(was: To remove engineering library from 49g) Message #6 Posted by Vieira, Luiz C. (Brazil) on 22 Feb 2005, 6:54 a.m., in response to message #5 by Eric Lundgren
Hi, Eric;
thank you so much for taking the time to check for the library's origin.
As you mentioned, if the library is a US$300 library, free copies are most likely to be illegal. I'd like to know what is it capable of, but surely asking for a copy (even by e-mailing you directly) would not be a good "behavior" of mine.
I'd add that, for as long as you can or want to, keep the library as it is in your 49G+. Based on what you read from others, the library itself won't slow your calculator down. And the HP49G+ has plenty of memory to hold it, mostly if you add a SD card.
Thanks again and best regards.
Luiz (Brazil)
