Lying flat -- 32SII and 11C Message #5 Posted by Karl Schneider on 18 Feb 2005, 12:34 a.m., in response to message #3 by James Stephens
Re: 11C
My 15C developed the annoying problem of not lying flat, and twisting ("straighening") the case did not solve the problem. Wwondering if some of the four screws underneath the rubber feet had come loose, I disassembled the case halves, re-twisted them flat, then reassembled. Voila!
This might work for your 11C. (Be sure not to lose the small spring that provides chassis grounding.) If you want new rubber feet, I think someone sells them on the MoHPC Classifieds.
Re: 32SII
All Pioneers have a wide rubber foot near the upper end, and four short rubber feet at the lower end. The calc's should lie flat, but they're not as readily disassemblable as the Voyagers (e.g., 11C) are.
-- KS
