Re: RAMBOX and HEPAX manuals Message #2 Posted by Wilson (Bill) Holes on 11 Feb 2005, 1:27 p.m., in response to message #1 by Jeff D
I am not aware of any site that has the mentioned documents in PDF form, however I believe both manuals are available on 'TOS' but in PaperPort (.MAX) format. The PaperPort viewer is available for free download at http://support.scansoft.com/downloads/default.asp, I know it has print capabilities. Adobe Acrobat claims to have the ability to convert to PDF from any application that can print. I therefore believe you could create your own PDF files from the .MAX files that are available on 'TOS'... That is provided you have Adobe Acrobat or at least have access to Adobe Acrobat. I hope this helps a bit!!
Edited: 11 Feb 2005, 1:49 p.m.
