Re: HP OmniGo 100 Message #2 Posted by Raymond Del Tondo on 4 Feb 2005, 10:11 p.m., in response to message #1 by Adam
It could be possible that you changed the batts
while the machine OS wasn't shut down.
You could try a soft reset, or if that doesn't work,
a hard reset using the reset pin hole.
Raymond
