Re: correlation programs for HP 49 Message #3 Posted by Vieira, Luiz C. (Brazil) on 2 Feb 2005, 10:11 p.m., in response to message #1 by Luigi Galletti
Hi, Luigi;
if you have the chance to take a look at the HP48G User's Guide (not the HP49G, the HP48G itself), look for Part 4, Section 21, page 21-10 under To perform a regression for two variables in the current data. and you'll see that there is already a [Best Fit] approach where the model with the correlation coefficient closer to 1 is set according to data stored.
If you are lucky enough having the HP48G Advanced User's Reference Manual (AUR), try page 3-65 under [CORR], the command that returns the CORRelation coefficient for a given data set.
Hope this helps.
Cheers.
Luiz (Brazil)
Edited: 2 Feb 2005, 10:13 p.m.
