Re: Hp 49g: tranferring files Message #2 Posted by Vieira, Luiz C. (Brazil) on 2 Feb 2005, 11:51 a.m., in response to message #1 by Dennis
Hi, Dennis;
chances are that the calcualtors have a different translation 'level', that can be set from 0 to 3, if I am not wrong. In this case, 'non-standard' codes like the one for "different of" is sent as \=/ (three bytes) if translation is set to 2 or 3 (I'm not sure about the exact code), or simply sent as a one-byte character (# 139) if no translation is required (Xlat set to 0). If the translation code is different, the receiver does not understand received data. In time: the translation is considered only in ASCII mode.
I remember having some problems when transfering data from an HP48G+ to an HP49G: errors everywhere. I solved them only after setting ASCII mode and Xlat 0. I also had problems with SysRPL data, but I'm pretty sure this has no solution.
Hope this helps.
Luiz (Brazil)
Edited: 7 Feb 2005, 5:36 a.m. after one or more responses were posted
