Re: HP-41CV Keyboeard Problem Message #3 Posted by Artur on 28 Jan 2005, 3:07 p.m., in response to message #2 by David Smith
After opening some HPs keyboards, I don't believe place a drop of alcohol is a good idea. The contact in 10 and 41 series is a little curved steel plate over the pcb and under a seal plastic. In some cases, may occur some oxidation, and alcohol may increase it, if it is not cleaned from the contact, as water will condense.
If the problem becomes serious, I have only one way to fix it: breaking all melting plastics (carefully) that tight the PCB to the case, removing the plastic partially around the key and cleaning it with a small piece of fine sand paper. By the way, clean everything and, after that, put back the plastic and mount the pcb to the case. You really do not have to glue the PCB to the case, because 41 has the screws on the back!
Good look!
Artur
