Re: HP 41CX display failure Message #2 Posted by David Smith on 27 Jan 2005, 3:39 p.m., in response to message #1 by Jim Stewart
Only source of a replacement display is another machine. Assuming your machine is a "fullnut" model, you can use this display from just about any 41C/CV/CX fullnut. Early 41C machines with the square epoxy blobs over the display chips may not work.
You can consider halfnut machines to not be worth the problems associated with repairing... removing the keyboard usually renders the machines unusable.
