Re: HP11C broken resonator Message #4 Posted by Tony Duell on 28 Jan 2005, 7:57 a.m., in response to message #3 by jean baptiste
Which version of the 11C is this? Is in the type with everything on one PCB, or does it have a removable logic module -- a flexible PCB in a plastic frame fixed to the back of the display
I thought (but will have to check) that the soldered-on components in the 11C and 12C were the 2 chips (NUT and R2D2), the clock inductor, the clock capacitor, and the electrolytic capactitor across the battery connections.
