Re: HP-21 battery drain Message #6 Posted by Vieira, Luiz C. (Brazil) on 26 Jan 2005, 12:04 a.m., in response to message #5 by Vassilis Prevelakis
Hi, Michel;
I have the HP21 schematics in hands right now (no, it is not an HP-original, it is a "volunteer" achievement, and there are no credits mentioning the author) and there is nothing but a series resistor connected to the batteries when the calculator is switched to OFF. The circuit ia almost like this:
/- - - - -| ON/OFF SW
_____/ ____ |
AC from___|\|__|_/\ /\ __|_____/ ___
charger |/| \/ \/ |
D1 R1 _|_
_ +
___ BATT
_ -
COMM
The series resistor is the only 1W (big guy), 8.2 ohms resistor that is connected to the charger when charging the calculator while it is switched to OFF. When ON, the resistor is bypassed, while the charger is used both for charging batteries and feeding the circuit. So, the only possible problem (if everything else is correct) resides inside the batteries themselves. OR (big OR) a problem with the ON/OFF switch (tabs printed in the keyboard PCB, must remove the plastic rivets).
Yes, I can send you a copy of the complete diagram (I cannot remember where did I downloaded it from), just drop me a line (I lost almost all of my friend's e-mail addresses... Sorry). I also have some news about your 41 MBoard: the equipments I borrowed (a two-trace oscilloscope and an eight-channel capture board with a digital-analyser Software) will be with me at the end of this very week. The "lender" needed them in the first minute after he offered them to me.
Hope this helps for now.
Cheers.
luiz (Brazil)
Edited: 26 Jan 2005, 12:35 a.m.
